Shift Light install on a 93
Old 05-10-2004, 11:28 AM
Gripenfelter's Avatar
Will this guide work for a 93 or will the wires be totally different?
http://missthang.50megs.com/electronics.htm
Gripenfelter is offline
Old 05-10-2004, 11:47 AM
badblackta's Avatar
as long as it has a negative, positive, and tach wire you should be good to go. Does that harlan light take pills to set the rpm? THta would be my only question about installation.
badblackta is offline
Old 05-10-2004, 12:14 PM
JasonL's Avatar
The Harlan uses DIP switches, no pills
JasonL is offline
Jason Short
01-19-2015 06:34 PM
blac94Z
01-12-2015 05:44 PM
07-04-2005 05:00 PM
MIGHTYMOUSE
08-29-2002 09:18 AM
Krab
08-05-2002 12:08 AM
Quick Reply: Shift Light install on a 93
