She faked an overheat
Old Feb 27, 2004 | 05:26 AM
terlox's Avatar
Question She faked an overheat
Here's what happened in a nutshell.
Engine is cold, starts up normally.
I let it idle for a few minutes then drive off. I notice the temp is higher than it usually is after only letting it warm up a few minutes.
I keep an eye on it but keep driving. Before I'm three blocks away I'm watching the temp gauge climb up to about 250.
I pull over as soon as I can. By this time it's about to hit redline. I pop the hood, I'm expecting to see coolant all over the place and a nice big hole in hose someplace.
Nothing, everything looked fine. I squeezed the larger hose going into the waterpump expecting it to be rock hard.
Not in the least bit. It felt like it would with had I checked it with the engine cold. I checked the coolant level - a bit high.
By this time I'm pretty close to my house so I start her up again. She starts creeping up to 230 or so. I gave it a little gas and it went back down! I give it a little more gas and it goes back down some more.
From that point on it's running around 190 which is pretty normal. I pulled over, let it idle a few minutes expecting it to jump back up.
Seemed fine. Everything is like normal.
What the heck happened here?
Old Feb 27, 2004 | 06:13 AM
GhostZ's Avatar
I hate when they fake it.
Old Feb 27, 2004 | 06:16 AM
magius231's Avatar
well, stock temperature for the second fan kick on is like 248 so are you sure it was above that? If so you may have had a sticky thermostat.
Old Feb 27, 2004 | 07:18 AM
I would replace the thermostat, for nothing more than the piece of mind. Real overheating issues can be costly on the LT1.
Old Feb 27, 2004 | 08:51 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
sounds like a thermostat to me. dont forget to protect that opti!!
david
Old Feb 27, 2004 | 09:31 AM
teke184's Avatar
piece of crud stuck in a hole or maybe in the radiator...
or in the stat for that matter
i agree with changing the stat...not a bad piece of $15 insurance and peace of mind
Old Feb 27, 2004 | 10:05 AM
terlox's Avatar
Ok, thanks guys.
Old Feb 27, 2004 | 10:11 AM
Gripenfelter's Avatar
You might have air trapped in your cooling system.
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Jmj93z28
Jul 8, 2015 06:58 AM
BOZS89IROC
3rd Gen / L98 Engine Tech
10
Mar 17, 2003 11:56 AM
94z28jbw
Mar 7, 2003 06:47 PM
