ShBox Website TDC
Old Aug 6, 2008 | 11:57 AM
Mtxz453's Avatar
ShBox Website TDC
Im on my last set of springs and the wierdest thing is happening. From what i remember, I used the diagram http://shbox.com/1/cam_timing_ani.gif and they were all right to reach TDC so my valvs didn't fall in, until I got to the last cylinder. I'm at TDC on piston #8 but the dowel from the cam that links into the timing gear is facing where #3 should be TDC according to the diagram.
Old Aug 6, 2008 | 12:49 PM
BUBBA's Avatar
The crank arrow/dot should be pointed at 3 o'clock when 8 and 5 are TDC. At any rate if both valves on 8 are closed you should be good to go. If you are in doubt, don't remove the valve seal until you are certain that the valve bottoms out on top of that piston. I.e. don't let go until you are sure. JMHO
Old Aug 6, 2008 | 01:08 PM
Mtxz453's Avatar
I have everything installed already, im just confused at this point i wanna make sure my timing is ok. When the crank pin that inserts into the timing gear is at 3 o'clock, cylinder number 8 is at TDC, shouldn't the pin be at 9 o'clock with cylinder #8 at TDC? Maybe I have the cylinders mixed up. Cylinder #8 is the one to the left and closest to the timing cover when facing the engine right?
Old Aug 6, 2008 | 01:48 PM
Originally Posted by Mtxz453
... Cylinder #8 is the one to the left and closest to the timing cover when facing the engine right?
Nope. If that is what you think, I am not sure how you got it done.
http://shbox.com/1/opti.jpg
Old Aug 6, 2008 | 02:31 PM
Mtxz453's Avatar
I'm honestly not sure either but somehow I did all the springs without dropping a valve in. Talk about luck. shoebox, your website really is an awsome guide.
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Fatdog2
Sep 16, 2015 11:04 PM
