shakes at idle, drives rough
Old Aug 19, 2007 | 11:56 PM
94redandblackz's Avatar
my 94 z is acting up lately and at idle it is shaking and when i drive its rough and has lost power, but when i rev it with out driving it revs normal, im thinking its something in the exhaust... maybe clogged cat.... any ideas
Old Aug 20, 2007 | 06:11 AM
afkevin_20's Avatar
i think it is cause im havin the same problem. one day i picked up someone in my shop, and he said it might be the exhaust. then last night i was coming on base and i asked the guy that was checkin id's and he said there was some smoke comin out. He said the cat might be goin out or clogged. goin to a muffler shop to see how much they would put my headers on and see if that know what the problem is.
Old Aug 20, 2007 | 09:55 AM
yea its sorta hard to explain i just started it up the other day and it was shaking at idle more than usual and didnt have barely any power but i know its not missin because it doesnt stumble its just rough throughout the whole rpms
Old Aug 20, 2007 | 03:02 PM
afr lt1's Avatar
My guess would either be a clogged up cat, to which you should unbolt your exhaust to see the effect that has on the revs. (get the cat off)
or
a burnt plug wire/wires.
Old Aug 20, 2007 | 05:16 PM
yea a clogged cat was the only thing that came to mind to me actually... does it sound like maybe a vaccuum leak like the others said, if so how do i check those?
Old Aug 21, 2007 | 10:42 PM
bump, its misfiring and there is a weird sound coming from the coil in the ignition system do you think replacing this would make my car run right again?! or plugs? help!
Old Aug 21, 2007 | 11:23 PM
Checking all plugs and plug wires is what I would do first. It could be just one wire (or plug) causing your miss.
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
F(ast)-body
Feb 26, 2003 09:05 AM
