SES wire help plz
Old Nov 2, 2004 | 04:06 PM
brad20653's Avatar
SES wire help plz
Took of AIR cant afford a tune now what wire can i cut to take out the ses light. Thanks in advance
Old Nov 3, 2004 | 01:44 PM
brad20653's Avatar
Re: SES wire help plz
noone knows?
Old Nov 3, 2004 | 02:08 PM
madwolf's Avatar
Disconnect the negative battery terminal and pull out the blue connector from the PCM.
Here are some instructions on how to do everything only you will be pulling out the wire #9 instead of 15. On 95s the wire is of brown color with a white stripe. It may be different on a 96, but the location is the same. Just make sure you find the numbers on the connector and take out #9.
Old Nov 3, 2004 | 03:13 PM
brad20653's Avatar
Thank you madwolf that did it.
mattszm6
Dec 14, 2014 07:09 AM
Elcojoe
Nov 17, 2014 10:27 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
