SES light .... vacuum leak sound... rough idle at startup?!
Old Jul 3, 2005 | 05:11 PM
AlwaysCode390's Avatar
Unhappy SES light .... vacuum leak sound... rough idle at startup?!
Hey guys, after I put that hypertech 95 chip in my 96 I took it out IMMEDIATELY , but now I idle REALLY rough at startup (from 500-1000 rpm spikes) and I have to keep the gas on a little for about 20 seconds , then it evens out and idles fine until I shut it off and try to restart it again, then I have the same problems. I also notice a vacuum leak sound when I am DRIVING only. At idle it sounds fine under the hood, but when I drive the leak sounds SO loud that I can hear it over my flowmasters IN the car!!!! It must be behind the engine near the firewall?! Whats back there to make the sound/leak? Is that probably why the SES light is coming on? ( to tell me about the vacuum leak? ). Should I take it to the shop since I dont see any cracked or disconnected lines, or did the wrong chip mess up my pcm and make it not be able to set the idle specs until I gas it for 20 seconds in neutral? Its so bad that if I dont put my foot on the gas at first it will stall over and over and wont idle ITSELF. Thanks-
Old Jul 3, 2005 | 06:27 PM
moparman's Avatar
Re: SES light .... vacuum leak sound... rough idle at startup?!
Take it to Autozone and have them pull the code. Get the exact code number then post what it is. Autozone has the capability to give you a printout of the code and the possible causes. You'll probably have to ask them to do it.
Old Jul 3, 2005 | 07:57 PM
Lightbulb Re: SES light .... vacuum leak sound... rough idle at startup?!
I actually posted in another thread, that I went to Auto Zone today and they said that the computer was giving back an "error link connection" return signal. Then he said he THOUGHT he heard a vacuum leak, lol.....but wasnt sure. I will post it if I can get my computer to stop acting up ( the emissions place said 4 things returned "not ready" signals from the pcm ).
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
