ses light flashing need help
Old Nov 29, 2005 | 07:04 PM
camaro79323's Avatar
car is running like ***. its stumbles real bad,idles rough and drives like its on a few cylinders. any ideas
Old Nov 29, 2005 | 07:26 PM
ChickenScreamer94's Avatar
Re: ses light flashing need help
Flashing SES = misfire. It's ignition most likely. Try the search button. There are alot of posts on this.
Original plugs and wires? its time to change after almost ten years anyway.
Get the code pulled and see what it says. It will help you more than throwing parts at it.
Old Nov 29, 2005 | 07:35 PM
blind527's Avatar
Misfire.
Bad plugs, burnt *old* wires, or opti issues.
Old Nov 29, 2005 | 08:10 PM
msd 8.8
ngk plugs
codes= multiple misfire
Old Nov 29, 2005 | 08:32 PM
UtOhCop's Avatar
Probably burned a plug wire
Old Nov 29, 2005 | 10:04 PM
plugs were all loose. tighten them can ran good for a mile or so then went back to doing the same. ses light flashing,car running bad and weak. i guess its the opti?
Old Nov 30, 2005 | 09:56 PM
changed the plugs today and the same runs good for about 5 minutes then goes down hill from there. could it be bad o2 sims? or o2 extinions? im gonna change the wires this weekend. anything else maybe???
Old Nov 30, 2005 | 09:59 PM
Mindgame's Avatar
Could be fuel fouling the plugs. What did the plugs look like when you pulled them? Did they smell like fuel??
-Mindgame
Old Nov 30, 2005 | 10:09 PM
they had a little black but mostly were white and didnt smell like fuel.
Old Nov 30, 2005 | 10:32 PM
SS RRR's Avatar
It's a stretch, but check to see if your water pump is leaking onto the opti via the weep hole.
Old Dec 1, 2005 | 05:02 AM
Guest47904's Avatar
Guest
Come on man, runs crappy you find they are loose. You tighten them and it runs good for a WHILE. Then you replace them (read tighten again)and it runs good for a while. Have you checked to see if any were loose AGAIN?
Tell tail sign is a shhh shhh sound (but not always)while it's running. some un practiced ears hear a ticking sound when actually it's the combustion by products running past the plug.
Old Dec 1, 2005 | 06:00 PM
did you not read that i changed them i guess they would be tight.
Old Dec 1, 2005 | 06:04 PM
Guest47904's Avatar
Guest
You just said enough. No need to guess anymore.
Heathen1
Jan 2, 2016 04:27 PM
Gtpguy
Jan 26, 2015 04:50 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
