ses light after man. fan mod
Old Aug 18, 2003 | 08:54 AM
Bobbys_97_Z28's Avatar
Angry ses light after man. fan mod
i did the manual fan switch, just like http://www.xious.com/camaro/install-fanswitch.html
and now im getting a p1641 code....how do i get rid of this! i dont want this whta the f***
Old Aug 18, 2003 | 09:02 AM
Add the 47 ohm resistors in this diagram and you will be good to go. If you can only find 1/2 watt resistors, they should work.
Old Aug 18, 2003 | 09:05 AM
ok
i have 1 1/2 watt 480 ohms in there, atleast im pretty certain!
Old Aug 18, 2003 | 09:18 AM
Re: ok
Look closely at the diagram. I am not talking about the resistors for the LEDs. Resistors between the switch and the connection to the green and blue fan relay wires is where they need to go.
Old Aug 18, 2003 | 09:25 AM
ok
so just splice into it and put a 1 watt with 100 ohms would be good?? if they even make those ones, or ill just find the 47 ohm ones
Magenta_Hearts
Mar 29, 2017 08:54 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
