SES Light
Old Sep 11, 2004 | 10:15 PM
transamdude95's Avatar
SES Light
Every once in a while, my 'Security' light comes on while driving. Could this cause my SES light that comes on when the engine warms up, which is what has been happening the last few days. I assume the 'Security' light is tied to the VATS, and sometimes I try to remote start/key start the car and it fails, leaving the Security light on and disabling the ignition for 5-7 minutes. Not sure why it does that. Could all this be tied together to cause the SES light?
Old Sep 11, 2004 | 11:27 PM
Re: SES Light
The security system is separate from the PCM. Probably unrelated issues.
The security light is likely because it is not reading the key pellet all the time. Get a scan to see what the SES is for.
Old Sep 12, 2004 | 01:13 AM
Re: SES Light
Cool, thanks for the reply. I might look into a new key then. Why would the Security feature kick in when I remote start occasionally? Is there a way to disable the Security feature? I'll get my car scanned Monday or Tuesday and give an update. Hopefully nothing major.....
Old Sep 12, 2004 | 07:36 AM
Re: SES Light
You did not mention remote start in the first post. Doesn't the key pellet have to be bypassed for remote start? I mean, your key is not in the ignition when you activate the remote start, so the VATS has to be faked out somehow. Could be whatever they put in there for the bypass is jiggling loose.
Old Sep 13, 2004 | 10:40 PM
Re: SES Light
Code 29: AIR CIRCUIT
Would that be the AIR? Or is it a sensor? I assume it's malfunctioning because I am missing a header bolt.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
