Serpentine belt squeak?
I ahve this squeaking sound coming from what i think is the tensioner on the engine belt. I only hear it when the car is warm and it seems to go away when the car is revved above idle. Does anyone know if this sounds right, and how much a new tensioner would cost?
Thanks,
Jeff
Thanks,
Jeff
Re: Serpentine belt squeak?
Ditto on that.
Also could be alternator bearings. To check, put a screwdriver on it and put your ear on the handle. I replaced mine at about 150K, but I have not had to replace the tension pulley yet.
i highly doubt it. just get some belt dressing and apply it. also may want to look at all the pulleys when the engine is running. even a little wobble is a problem with belts.
Originally Posted by JeffsWorld
Where do you find GatorBack belts? Will any parts store carry them?
