Serpentine belt question.
Old May 20, 2005 | 02:00 PM
desertfox's Avatar
I did remove my air condition system from my Z28 permamently . After that, what size serpentine belt I have to get to fit in?
Old May 20, 2005 | 02:04 PM
NOMAD's Avatar
Re: Serpentine belt question.
You have to have a A/c Delete pulley for it to route correctly. You use the stock belt, but a Idler pulley in place of the A/C
-Shannon
Old May 20, 2005 | 02:05 PM
Patrick96Z28's Avatar
same belt that you used with the ac in. I just did that and the same belt does not slip & works perfect. I heard of people saying you need a shorter belt because the tensioner pulley does not pick up enough slack when you are missing your compressor. I have not had that problem. My 1LE ac delete pulley works fine.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
Latronaxe
Jul 20, 2015 12:00 PM
