Serpentine Belt
Old Dec 12, 2004 | 01:20 AM
blaze309's Avatar
Serpentine Belt
I know i have to remove the serpentine belt for my header install and i was wondering if i had to have a special tool for the belt tensioner. Or does can you just use a socket and wrench on this? If so how hard is it to remove with those?
I just remember a few years ago when i was helping my neighbor with his car he had to go get some special tool from autozone to help remove the belt. It may have just been a big extension bar with a socket on the end.
Old Dec 12, 2004 | 01:50 AM
MarkyMark's Avatar
Re: Serpentine Belt
I cant remember the exact size, but I think it is a 15 mm socket and you just pull the tensioner down. No special tool required and it is super easy.
Old Dec 12, 2004 | 01:57 AM
blaze309's Avatar
Re: Serpentine Belt
Alright cool that's what i figured is you just get a socket and wrench and rotate it counterclockwise i was just making sure so i don't run into problem when trying to install my headers.
Old Dec 12, 2004 | 02:01 AM
lamb110's Avatar
Re: Serpentine Belt
yep i just put on a new Underdrive pulley today and i used a 15 mm socket/drive
took all of a half hour to do, really easy
Old Dec 12, 2004 | 07:53 AM
Re: Serpentine Belt
It's a 13mm on my car. You turn it clockwise.
Old Dec 12, 2004 | 10:41 AM
moparman's Avatar
Re: Serpentine Belt
It'll take you longer to jack the car up than it will to replace the belt.
Old Dec 23, 2004 | 08:20 PM
Beyonce Knowles's Avatar
Re: Serpentine Belt
Did shoebox just happen to know that or does he look these things up someplace? shoebox
Old Dec 23, 2004 | 09:15 PM
NOMAD's Avatar
Re: Serpentine Belt
1/2 works also
Why are you removing the serp belt to install headers ?
-Shannon
Old Dec 23, 2004 | 09:26 PM
Mtrhds94Z's Avatar
Re: Serpentine Belt
Originally Posted by NOMAD
1/2 works also
-Shannon
Alternator comes off.. so belt comes off too..
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
