Serious and very strange misfire issue....not the obvious...experts inside please!!!
Old Oct 8, 2004 | 10:31 PM
  #16
turbo_Z's Avatar
Re: Serious and very strange misfire issue....not the obvious...experts inside please
I take it you dont have a spare PCM. But if you did Id definitely give that a try. Just b/c the car starts up doesnt mean the PCM is 100%... the flash chips are fine but maybe some of the wiring is messed up sending and interpreting false signals. Just a thought.
Have you tried adjusting the rockers? Maybe you have a couple of em too tight.
Old Oct 9, 2004 | 12:31 PM
  #17
SSTAT's Avatar
Re: Serious and very strange misfire issue....not the obvious...experts inside please!!!
Sorry to keep bringing this back up but... I had a similar problem, started by inspecting wires - were fine, went on a huge search for something else, no help - went back to wires and found that one was melted apart inside the OPTI boot! I didnt consider 'checking wires' to include the opti end but I should have, or put them on an ohm meter-
Old Oct 10, 2004 | 08:31 PM
  #18
Whitewolf's Avatar
wires are fine..have been checked with ohm meter...
still searching..
I have no clue.
Old Oct 10, 2004 | 08:47 PM
  #19
ramairimpala's Avatar
wires can ohm out fine and still have an small break in the insulation. Replace your plug wires especially since it isnt a random misfire it in on 2 cyls.. Just replace the wires. Trust me.
Old Oct 10, 2004 | 10:20 PM
  #20
Whitewolf's Avatar
not the wires............................
Old Oct 11, 2004 | 07:32 AM
  #21
Jon97Z's Avatar
If you're sure its not the wires, there's a chance it could be the coolant sensor on the water pump. I had a miss/misfires that was driving me nuts for a long time. Turned out to be the sensor on the water pump wasn't tightened all the way up. My old water pump went south and I replaced it with an OEM new one, and replaced the sensor as well. But failed to tighten it up all the way. (Afraid I was gonna strip out the brass fitting if I put too much force into it.) I never would've thought that would've made my car run weird, but it did. I'm not sure if there's a full proof way to check it and verify its functionality though. I just replaced it with a new. From what I remember, it wasn't pricey. Just a suggestion....
IndyZman
Oct 22, 2015 02:17 PM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
