self aligning roller rockers?
Old Apr 24, 2003 | 11:45 AM
94droptopz's Avatar
whats the advantages and disadvantages to running them? should i put SA or non SA on my 396? thanks
Old Apr 24, 2003 | 12:00 PM
ArrestMeRed's Avatar
Well this is what I heard. Self aligning is ok for cams up to .550 lift, over that, you need non self aligning. Non aligning is kinda of an SOB, because you have to adjust them every so often.
Old Apr 24, 2003 | 12:46 PM
J's 82's Avatar
Self aligning have little "ears" on them to keep them centered over the valve tip.. non-self aligning don't and require guideplates or the have the possibility of wandering on the vavle tip.. not sure if that can cause damage but can't be good..
Old Apr 24, 2003 | 01:38 PM
xxsaint69x's Avatar
i am using SA 1,6 rockers with CC306 Lift is .576..i have no problems
Old Apr 24, 2003 | 01:45 PM
Rodrigues's Avatar
I like my SA rockers, you cant hear them over the exhaust anyways.
Old Apr 24, 2003 | 01:50 PM
All_Z_Way's Avatar
Most engine builders prefer the non-SA for higher hp engines. I honestly don't for sure why that is.
I don't see where having SA or non-SA would make any difference on adjustments though.
Old Apr 24, 2003 | 01:53 PM
llafro's Avatar
From what I understand, the NSA versions behave in much the same way as the SA. It's just that they require guideplates. The NSA, however, are much more stable, especially at higher lifts. The SA rockers stay right on top of the valve, but they can move around some on the pushrod end. The guideplates keep the pushrod end in place on the NSA, which keeps the whole rocker aligned better.
The basic reason the manufacturers went to the SA version is for cost. If you don't have to put guideplates on, then you save the cost of the plates, save weight, and save a step in the assembly process. Think about it. If you could save maybe $20 per engine by changing the design, multiply that out by millions of engines, and it becomes a lot of money. Not everything the carmakers do is to make better engines.
BRAD
95 red TA
Old Apr 24, 2003 | 02:54 PM
There is no difference in frequency of adjusting that I am aware of.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
