Seeking stock LT1 engine info.
trying to input info into Dynosim, and the power curves are way off... indicated flywheel HP is below my RWHP. so i have some inaccurate data in it. Cam specs, flow specs, etc is what im looking for.
Whats in blue text can be changed, Yellow cannot.
DynoJet Dyno reading, 236 is RWHP and 290 RWTRQ.
Re: Seeking stock LT1 engine info.
http://www.ls1tech.com/forums/showth...52#post2682252
Anything I've ever wanted to know about an LT1's stock specs is there.
And as you would see i responded that i found the proper cam LSA/Centerline and that it wasn't enough to affect the curves much at all. not nearly enough to get it to expected levels. LS1Tech is LS1Tech. CZ28 is CZ28. just because you and i are in both places, doesn't mean others with good info are.
here's what happened when i fed in stock cam data from the other link..
Errr... WTF? nearly 400TRQ right at the outset? me thinks somthing funky is up. I only included changed data.
Headflow data.
Headflow data.
Don't expect the Dynosim to show you reality - it won't. IMO it's not even close. I have it and I only use it to see the differences between changes. So, only compare Dynosim graphs to Dynosims graphs. Don't compare it to reality.
I dont expect spot on accurancy. 15% or so variance would be fine. nearly impossible for mathmatical calculations to handle minute variances in a individual engine that can either hamper or help performance.
Is there a SFI option under intake manifold type in that program?
http://www.ls1camaro.net/freehosting/stockLT1sim.JPG
