Security Light stayed on Car wouldn't do anything!!??
Old Aug 14, 2003 | 08:12 PM
95BlackBird's Avatar
Question Security Light stayed on Car wouldn't do anything!!??
Went out to goto work the other morning, Tried to start her up and nothing happened!! Looked at the dash Security light was on solid. Not flashing as normal. Everything worked (radio was on blower moter from A/C was blowing) you know the normal things when you turn on key. Took the key out got mad called it all kind of names, Few minutes tried again and everything normal!!???? Any Ideas?
Old Aug 14, 2003 | 08:25 PM
AsianSensation's Avatar
Your resistor pellet in your key is probably dirty.
Old Aug 14, 2003 | 08:51 PM
Should I just clean the key or try to clean the key switch? Problem is I didn't take the key out the night before I leave the keys in overnight!
Old Aug 14, 2003 | 08:57 PM
Brent94Z's Avatar
Super Moderator
You could just bring over a 12 pack of The Beast and we'll take a look at it Assuming, of course, you can get it past this glitch to bring it over
Did it not start for you even after about 10 minutes? If it didn't, did the light stay on the entire time (longer than say 10 minutes) or was the light out but then immediately when you went to start it again the light came on?
You know my number if you'd like to call so I don't have to get carpal tunnel syndrome typing
Scottylt1
Jan 8, 2015 02:48 PM
fpete1992
Dec 11, 2014 03:51 PM
Scottylt1
Dec 4, 2014 12:31 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
