Security Light + No Start????
Old Aug 7, 2003 | 06:25 AM
kgkern01's Avatar
Angry Security Light + No Start????
Posting this here to get a better response. I'm having a problem with starting my friend's 96 V6 camaro, when he places the key in the ignition to start, the security light comes on and will not allow me to start my car, after about 15 minutes it resets itself and light will go off and at that time I can start the car, this is an everyday occurance, can someone help???? Has only done this since replacing the alternator and battery a few days ago.
Old Aug 7, 2003 | 06:57 AM
Stormman's Avatar
Clean the diode on the key. Happened to me and it seems to be the fix.
Old Aug 7, 2003 | 07:10 AM
jim88iroc305's Avatar
Cool
sounds like a PASS-Key II issue with chip in key. try using his extra key to see if symptom remains. like mentioned above key might need some cleaning. It can also happen if the key is wet; so make sure key is dry.
good luck
Old Aug 7, 2003 | 07:21 AM
ONELOUDKAR's Avatar
happens to me as well every once in a while... try the cleaning method or the other set of keys
eazyZ
Mar 1, 2015 07:12 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
