!!!!!!!!!security??!!!!!!!!help!
Old Jul 4, 2006 | 11:19 PM
baddboy1705's Avatar
Exclamation !!!!!!!!!security??!!!!!!!!help!
I need help ASAP! drove my 96 Z over a friends and it will not start. all the electronics turn on(radio,AC,ect.) but the car wont turn over... there is however a orange "security light" on my cluster that is on now also... i need to get home now! please help any ideas.
--i have already tried killing the power from my battery for 30 minutes... didnt work
Old Jul 4, 2006 | 11:23 PM
WeirdRich's Avatar
Re: !!!!!!!!!security??!!!!!!!!help!
maybe a vats problem?
Old Jul 4, 2006 | 11:25 PM
LT1_383's Avatar
Sounds like the resistor in your key or the ignition cylinder is worn out. I have this problem every so often. I get out of it one of two ways. I use the remote start, put my key in, turn it to run and hit the brakes to shut off the remote start system. OR i use my spare key. Hope this helps.
Old Jul 4, 2006 | 11:34 PM
my spare key is about 50 miles away in my room....and the key i have is a fairly NEW key....still not starting....
Old Jul 5, 2006 | 12:00 AM
Old Jul 5, 2006 | 12:22 AM
GnarlyZ28's Avatar
I had the same problem, how many times have you tried to turn it over? After about 30 tries it started right up, but once I started it up i had to try and crank it about 30 more times for it to start again once i turned it off, the dealer said it was a problem with the security system, plus i had a bad starter.
Hope this helps.
Old Jul 5, 2006 | 01:52 AM
whitehooptie's Avatar
when you stick your key in and turn it on, does the light blink?
Old Jul 5, 2006 | 04:20 AM
trymy6's Avatar
I have a smilar problem with my '93. Sometimes when I drive it, the security light comes on and stays on for the duration of the trip. I do NOT have an alarm on it. The car always starts though....
Old Jul 5, 2006 | 12:43 PM
nope....just a steady on
Jeff1904
Jun 5, 2016 05:00 PM
walt355
Mar 16, 2016 09:35 AM
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
