secondary air injection
Old Sep 30, 2007 | 11:19 PM
96supersport's Avatar
secondary air injection code, what is that exactly?
how do i fix it?
Old Oct 1, 2007 | 12:39 AM
Irish350's Avatar
thats your AIR
its an emmissions thing
basically, its the 2 tubes going into the #1 and #2 primaries, which then go into the air pump on the drivers side head
if i remember right there are more than one codes pertaining to it
Old Oct 1, 2007 | 12:14 PM
Need the exact code. There is a code for air flow failure to each bank of the exhaust (P0410) - could be failed check valves, pump not working; and another for electrical fault in the AIR pump circuit (P0412) - most likely a blown fuse.
Old Oct 1, 2007 | 01:39 PM
its the P0410
Old Oct 1, 2007 | 03:10 PM
Ok4thGen's Avatar
Before Injuneer hurts his fingers from typing it again heres a link to a post with a more then detailed explanation of your problem
http://web.camaross.com/forums/showt...ighlight=P0410
Sauced
Mar 29, 2015 10:53 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
