Sealing Inlet Elbow?
Old Jul 21, 2007 | 12:45 PM
_94Lt1_'s Avatar
My stock rubber inlet elbow has a few about 1" long cracks in it, makes a noticeable whistle when running. Is It Ok to use a sealant to seal/prevent air leaks? I ordered a Trick Flow one today, but need the car tonight. Is this gonna hurt anything ?
Thanks in advance.
Old Jul 21, 2007 | 12:57 PM
oneclean97z's Avatar
i would not trust sealant, last thing you want is that stuff going into the throttle body and who knows what could happen. just drive how it is but dont go in dusty areas, just my .02
Old Jul 21, 2007 | 12:59 PM
dangalla's Avatar
you get the award for worst advice i ever seen on cz28
photo deleted[/i]g[/img]
those cracks are allowing unmetered air into your engine, just find yourself a new elbow pronto
Old Jul 21, 2007 | 01:07 PM
speed_demon24's Avatar
Putting some RTV on the cracks to hold you over shouldn't cause any harm.
Old Jul 21, 2007 | 01:19 PM
phot deleted[/i][/img]
you are absolutely right, that is by far the worst advice ever given on here. hey you want me to bow down and shine your shoes too?
Last edited by Injuneer; Jul 22, 2007 at 11:19 AM. Reason: Watch the language. If you guys want to argue, take it off line.
Old Jul 21, 2007 | 01:42 PM
_94Lt1_'s Avatar
What about the stock airflow sensor that plugs into the elbow? Do Trick Flow ones have a place to just plug that into or what ?
Old Jul 21, 2007 | 01:43 PM
dangalla's Avatar
you are absolutely right, that is by far the worst advice ever given on here. hey you want me to bow down and shine your shoes too [edit]?
if ya want to but i would rather you just didnt give ridiculous advice thats only going to hurt someones motor
Last edited by Injuneer; Jul 22, 2007 at 11:18 AM. Reason: You can tell make your point without being so sarcastic.
Old Jul 21, 2007 | 01:53 PM
yes they do.
Old Jul 21, 2007 | 01:55 PM
_94Lt1_'s Avatar
yes they do.
Thanks so much for your time. you've been very helpful and quick responding.
Old Jul 21, 2007 | 04:23 PM
[deleted]
Old Jul 21, 2007 | 04:27 PM
LowRyter's Avatar
my plastic tube (Hennesey) was cracked. I trimed it with shears & used duct tape. Cleaned out the K&N, sprayed some carb cleaner in the TB, new PCV, and WOW, runs good.
Old Jul 21, 2007 | 04:29 PM
LiENUS's Avatar
Duct tape is probably your best bet, I've also seen some stuff thats like aluminum foil but with one side sticky, works great for fixing intake tract tears, dunno what its called though.
G-BODYT56
Jan 14, 2022 11:14 PM
marlar98
Oct 21, 2015 02:02 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Slayer
Aug 17, 2015 03:55 PM
