Seafoam??? what happend???
Old Mar 12, 2005 | 10:57 PM
Heatmaker's Avatar
Advanced Member
I just sea foamed my car... and didn't get any smoke or anything you guys talk about.. do I need more seaman Foam??? I poured like a Pint in the crank, and a can in the tank... I didn't get nuthin... not even a fart from the car... what gives??? Maybe I need to pour a Gallon in there or somthing..
Old Mar 12, 2005 | 11:05 PM
Re: Seafoam??? what happend???
LOL, you don't get smoke from pouring it in where you did. It's only when ingested in heavy concentration to burn in the cylinders (like through a vacuum line).
Old Mar 12, 2005 | 11:06 PM
hotrod18_69's Avatar
you'll only get a crap load of smoke if you spray it into the intake manifold itself.. You just put it in the crankcase and the fuel tank, which is fine. But if you do the intake that will help too. It will clean all the carbon deposits and crap. Just let it sit in there for about 15mins or soo and you'll be good.
Old Mar 12, 2005 | 11:11 PM
Heatmaker's Avatar
Advanced Member
uuggghhh I think I need to take another trip to autozone...
Old Mar 12, 2005 | 11:18 PM
Robs97Z28's Avatar
LOL, Dude! If you want smoke it is on the way. You can use the power brake vac ling, but you will need to reduce the line size. Find a way to make the hose smaller, or you will kill the engine as soon as you stick the hose in the can.
Old Mar 12, 2005 | 11:27 PM
Heatmaker's Avatar
Advanced Member
any vaccum line will do though correct... how bout if I used one of the smaller lines on the pasengers side of the intake... too small???
Old Mar 12, 2005 | 11:33 PM
Robs97Z28's Avatar
No, it does need to be long enough. It also needs to feed all the cylinders. Most of the small vac lines are close to intake prots, so, it would just a few intakes and not all of them.
Old Mar 12, 2005 | 11:35 PM
iNF3RNo's Avatar
Pour it from the can into the brake vaccuum line.
Don't smother the engine bad enough to stall.
That's the non-rocket science solution to the "line being too big."
Old Mar 13, 2005 | 06:47 AM
Eff's Avatar
Eff
Just use the brake booster line.
I think the easiest way to do it is to pour it in to a can or something with a bigger opening. Keep your thumb over the booster hose and start the car.
then put the hose in to the sea-foamand just barely move your thumb.
Once you do it a few times it gets pretty easy to do.
Old Mar 13, 2005 | 09:20 AM
LT1Squirrel's Avatar
or just modulate how much comes out by the angle of the can while youre dumping it into the line, it'll suck it in so no need to worry about spilling any....and change your oil soon cuz now all that crap the seafoam dislodged in your CC is floating around in your oil
Old Mar 13, 2005 | 12:21 PM
hatredizm's Avatar
Is this stuff really that good? And is it worth it to do this? Never used it and have only heard about it after seeing it on this site. I also heard someone before mention 'spraying' it into the throttle body. is that correct also? Thanks.
Old Mar 13, 2005 | 02:17 PM
it is all its made out to be, the aerosol youre refering to is called 'deep creep' its just regular seafoam in a spray can
Old Mar 13, 2005 | 02:35 PM
Heatmaker's Avatar
Advanced Member
ok I tried again... through the booster...poured like 20 cans down there... plenty of smoke... 1st gear sucks.... but otherwise things seem to be running stronger... but I can't tell what's doing what really becasue I installed mustiple modes at the same time..
Old Mar 13, 2005 | 02:57 PM
94zLT1's Avatar
ummmm did u say 20 cans?
Old Mar 13, 2005 | 03:01 PM
Heatmaker's Avatar
Advanced Member
nah... more like just 2-3....
and some Deep creep...
uhhh....
No problems.......
uhhh... yet...
