Seafoam Makes Driving Worse
Old Dec 17, 2010 | 07:58 AM
  #16
bw_hunter's Avatar
Re: Seafoam Makes Driving Worse
A hundred ? Wow, that's a lot of reasons!
The only effective way to diagnose any problem is to fix known issues, eliminating them as even potential. The OP should fix his fuel pressure problem before moving on to anything else. The fuel pressure issue might not be the fuel pump, it might be the regulator or even a feed line kink.
There are several assumptions that this is caused by 'gunk' that is being knocked loose. No such 'gunk' has been seen that I can tell. It might not even be the gunk at all...who knows.
Fast and Blue, fix the fuel pressure issue, then remove and have the injectors cleaned if you still think that's the problem. Maybe even switch them out with someone elses to see if that results in a different response.
Old Feb 25, 2011 | 01:11 PM
  #17
JustCruzin's Avatar
Originally Posted by slopokrodrigez
I got a hundred reasons your problems are not even related to a fuel pump issue.
Here's a good example. Suppose the "gunk" you refered to in the fuel rails got in the FPR holding it open and releasing some of the pressure back into the return line?????
I seriously doubt your pressure problem is from the pump.
Good point, that same "gunk" can make it's way to the injector filters
Old Feb 25, 2011 | 02:39 PM
  #18
spilner's Avatar
I just put seafoam in my truck. 97 diesel suburban, 295,000 miles. It started missing a little on idle and take off. Added seafoam, runs like new! I love that stuff lol
Old Mar 2, 2011 | 05:08 PM
  #19
nosfed's Avatar
I'd never want to put a substance in my fuel tank that runs all the garbage in the system through the injectors. A few years ago I took my truck to a friendly mechanic for a brake job. For whatever reason he decided to run that stuff through my tank, and the truck developed a lean pop immediately. The seafoam dislodged some junk that wound up in the TBI injectors which had to be replaced.
Another benefit to using Seafoam in the oil system is that it removes all the crud that's keeping your old gaskets from leaking! Yeah, I got to put a set of valve cover gaskets on the old truck after he ran the stuff in my crankcase too .
That can of snake oil cost me half a day's labor and hundreds of dollars.
Old Mar 2, 2011 | 06:47 PM
  #20
transAMdriv3r's Avatar
you may have some fuel pressure but maybe the pump isnt putting enough volume out
Old Mar 4, 2011 | 10:35 AM
  #21
rocknroler69's Avatar
Did you check the fuel pressure regulator? if thats bad you could end up with low pressure
Old Mar 4, 2011 | 04:01 PM
  #22
Guest47904's Avatar
Guest
Please let this thread die already. The OP hasn't even been in this thread since December. Seems he starts and drops thread like you and I throw out bath water.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 23, 2015 01:13 PM
guionM
14
Jun 19, 2002 08:30 AM
