screeching noise
Old Jan 5, 2004 | 04:03 PM
8-Pack's Avatar
screeching noise
I have a 95z28 and it is making a screeching noise (kinda like a chain draging the ground), after I bring the car to a stop and then start moving again. It tends to stop after I get up to about 40-50 mph. It does make the noise when I stop the car, but it is not really that bad until I get off the brakes and start moving again. Also it does not do it in reverse. Any help is greatly appreciated
Old Jan 5, 2004 | 04:57 PM
95BlackTA's Avatar
Get a new belt?
Old Jan 5, 2004 | 05:12 PM
8-Pack's Avatar
The noise is coming from the rear of the car, also it does not do it while idling only when i'm moving forwards so I am pretty sure it is is drivetrain related not engine
Old Jan 5, 2004 | 05:22 PM
95BlackTA's Avatar
What kinda gears you have? ive heard if you install like 3.73s they make noise. You should check your diff fluid, and go ahead and do a diff fluid change while you're at it.
Im not sure, im sure someone else will chime in...
Old Jan 5, 2004 | 05:39 PM
8-Pack's Avatar
I thought it might be the diff, but why would only do it in a forward gear and not reverse?
Old Jan 5, 2004 | 05:55 PM
95BlackTA's Avatar
Reverse is a completely diff ratio I think, and uses a differnt synchro or something. I dont much about them at all, but that would seem to make sense to me.
Old Jan 6, 2004 | 09:21 AM
8-Pack's Avatar
reverse is first gear, I also have an A4 so I am pretty sure I dont have synchro's
Old Jan 7, 2004 | 09:27 AM
8-Pack's Avatar
Anymore suggestions I am going to try and get the car on a lift this weekend and look around any other suggestions would be great
Old Jan 8, 2004 | 11:10 AM
8-Pack's Avatar
Also when i push the brakes the noise is constant but when I let off them the noise is intermittent and gets less frequent as I speed up until it stops. It will do it randomley if i am on the freeway but only for a few seconds then it stops
Old Jan 8, 2004 | 11:29 AM
Guerardsgt's Avatar
I would not suspect it to be the diff in this case. I would check your axle bearings on this one. Your really not moving fast enough in reverse to actually hear a screaching noise. When your going forward at a somewhat moderate speed the bearings heat up and thats where I would suspect the noise to be coming from. I would get someone to listen for a scraping noise while moving the car slowly so you can pin point which side its coming from. The only way I would think it would be the diff is if your hearing a loud whining noise while driving. Good luck
I just looked at your new post while I was writing this reply. If thats the case check your brake pads and rotors. If the brakes get to low they can scrape a steady line in your rotors. If it's only doing it for a few seconds your rotors may be warped.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
