scanning an OBD1 conversion car
Old May 16, 2004 | 05:21 AM
QCKZ28's Avatar
will the free scanner at autozone work on my car
a 96z28 that has been converted to OBD1 by pcmforless?
Old May 16, 2004 | 05:30 AM
97WS6SCharged's Avatar
If they have a scanner that will work on a 95 then it should work.
Old May 16, 2004 | 03:38 PM
QCKZ28's Avatar
do OBD1 and OBD2 have the same connector?
jesse
Old May 16, 2004 | 03:50 PM
jchevy's Avatar
The 95 obd1 cars share the same connector as the OBD2 cars. You will need a scanner for a 95 car to check to codes on your 96 that has beed converted to OBD1.
Old May 16, 2004 | 04:03 PM
You think AZ is confused when they try to scan a normal 95 f-body, wait until they try to scan a 96 that has been converted to OBD-I. It will likely be beyond their comprehension.
Since they only scan real OBD-II cars anway, I doubt they will be able to help you.
Old May 16, 2004 | 06:54 PM
QCKZ28's Avatar
thanks
Queens94z28
Dec 20, 2014 09:11 PM
brentbrowning01
Dec 16, 2014 06:35 AM
cmdeshon
Dec 12, 2014 10:51 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
