Scanned car, all data here..need help
Old Aug 26, 2004 | 06:42 PM
luis nunez's Avatar
So I took the car to pep boys and 3 days later they told me to take the car to a local GM..here is the data that they had when they scanned the car
1995 LT1
Z28 m/6
vt-100 Live Data----
RPM 0 left int _128 right int_128
16 Low resolution pulse failure
42 est grounded
36 High resolution pulse failure
48 mass air flow system failure
33 map sensor or circuit too high
open/clsd loop open coolant F173
left 02s(mv) 752 right 02s(810)
left blm 128 right blm 128
a/f learned ..no ft cell --0
tps(v) 0.58 throttole%-0
left bpw (ms) 0.0 right (ms) 0.0
airflow (gm/sec) 0 IAC position 101
coolant 173'' mat(f)104
Fan 1 no fan 2 no
map(KPA) 103 map (V) 5.00
baro (kpa) 103 baro(V)5.00
knock no knock retard 0
spark adv 0 ignition 12.3
ccp duty cycle 0 egr duty(%) 0
time 0.00 desired idle 3188
the guy todl me that the computer looks to be bad?
the car shuts down when driving, the is really hard to start, backfires the RPMs co up and down. with back fires..
Old Aug 26, 2004 | 08:13 PM
HBHRacing's Avatar
Re: Scanned car, all data here..need help
I would be looking at the opti connector myself. CHeck for good contact and corosion causing a fault. since the codes point to both the loss of high and lo res. the grounded ICM circut code seems to come up a lot with opti codes but that is where I would startif it was me. Data doesn't help a whole lot unless the fault is present at the time of the scan.
I would clear the codes as well and see what comes back first
Old Aug 26, 2004 | 08:19 PM
Ryan's LT1's Avatar
My car was spitting out codes for everything when I my opti went out... Definately check there first.
Old Aug 26, 2004 | 08:30 PM
luis nunez's Avatar
I took a look at the opti cable and the previous owner replace it, it is almos new, I will put that same cable of my LT1 A/4 to see and also clean the conectors with that electrical cleaner...
this is anothe info that I was able to take home
RPM 5005 left int 128 right int 128
code and data ok to drive
42 est grounded
36 high resolution pulse failure
open/clsd loop .. open coolant 126''
left 02s (MV) 960 right 02s(MV) 159
a/f learned no ft cell 16
tps(v) 0.58 throttole(%) 0
left bpw (ms) 1.3 right bpw (ms) 4.4
airflow (gm/sec) 2 IAC position 10
coolant 126'' mat (f) 107
fan 1 requested yes fan 2 requested yes
map (kpa) 103 map (v) 5.00
BARO (KPA) 103 BARO (V) 5.02
knock NO knock retard 0
spark adv 21 ignition 11.1
ccp duty cycle 0 egr duty % 0
time 1:14 desire idle 800
Thanks for the reply
jayblev95
Jan 20, 2015 01:30 PM
brentbrowning01
Dec 16, 2014 06:35 AM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
Brent94Z
Mar 21, 2002 04:44 PM
