scanmaster install help, quick question
Old Dec 6, 2003 | 03:55 PM
PredatorZ28's Avatar
i have a 95z with odb I and a odbII connector ,, do i hook it up like a odbII?
Old Dec 6, 2003 | 05:18 PM
TTT and post 500lol,... help
Old Dec 6, 2003 | 07:14 PM
anaik's Avatar
This is the way I hooked mine up.
http://www.bfranker.badz28.com/fbody/scanmaster.htm
Old Dec 6, 2003 | 08:25 PM
u have odbI with odbII connector?
Old Dec 6, 2003 | 08:48 PM
95 Silver TA's Avatar
I have a 95TA just like your setup (OBD1 pcm with ODB2 style connector from the factory). I hooked it up to the pin on the lower left of the ADL connector.
Hope that helps,
Claude
Old Dec 6, 2003 | 09:44 PM
the tan one like stated for a odbII?
Old Dec 7, 2003 | 12:25 AM
Old Dec 7, 2003 | 01:15 AM
guess ill just try the odbII way
Old Dec 7, 2003 | 01:22 AM
anaik's Avatar
It'll work.
Old Dec 7, 2003 | 09:19 AM
Brent94Z's Avatar
Super Moderator
Even though you have an OBDI PCM you have the OBDII connector which still shares the same pinouts as the OBDII PCM. GM made it easier by keeping the connections the same in the connector so there are only two styles of plugs... OBDI and OBDII and not OBDI, OBDII, and OBD-1995 style
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
thenewkid
Nov 29, 2014 04:54 PM
