Scan results
Old Jun 18, 2007 | 08:24 PM
ZL1modified's Avatar
Scan results
i thought everything looked good until i scrolled down...
this can't be right, can someone tell me what might cause this...
i wasn't even at wot... did my tool go bonkers? or is my pcm screwed up... i have been having problems running rich and wot response...
MIL STATUS ON
ABSLT TPS % 81.1
ENG SPEED RPM 4021
CALC LOAD % 68.6
MAF FLOW g/Sec213.06
MAP KPA 191
COOLANT F 120
IAT F 275
IGN ADVANCE -39.1
SECOND AIR ATMOS
ST FTRM1 % -5.1
LT FTRM1 % 56.2
ST FTRM2 % -88.3
LT FTRM2 % -34.2
VEH SPEED MPH 157
FUEL SYS 1 CLSD1
FUEL SYS 2 OPEN2
O2S11 V 1.235
ST FTRM11 % 73.4
O2S12 V 1.035
O2S21 V 1.165
ST FTRM21 % 15.6
O2S22 V 0.430
OBD2 STAT N/A
Frame -149 Time-2474.9
Old Jun 19, 2007 | 11:41 AM
i know it's not the greatest topic or thing to talk about... but i would appriciate some insight on why i got these codes... i'm sure someone in the lt1 obd2 world can give me some insight...
Old Jun 19, 2007 | 12:15 PM
blue89rs's Avatar
Looks like EVERYTHING is off. Must be the tool. How many times have you tried this and got the same values?
Old Jun 19, 2007 | 12:52 PM
this is the first... the only thing close to right are the rpms... but if this is what my pcm is really putting out then i think something is really ef'd up...
seems like it happened after the car got nice and warmed up...
the last 4 frames of the scan ended up like that with different "off values"...
i'm gonna scan it again tonite and see if it happens again...
Old Jun 19, 2007 | 01:55 PM
blue89rs's Avatar
Good plan. You may want to check another car just to make sure the tool is working right.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
KYWes
Sep 26, 2015 08:49 AM
HAWG
Sep 25, 2015 11:41 AM
tommalcolm
Sep 11, 2015 03:39 PM
