sbc roller rockers on lt1
Old Apr 3, 2012 | 01:48 AM
greenformula94's Avatar
Do sbc roller rockers fit on lt1's?
Old Apr 3, 2012 | 05:17 AM
Guest47904's Avatar
Guest
Re: sbc roller rockers on lt1
Narrow ones do with stock valve covers.
Old Apr 3, 2012 | 05:20 AM
lt1-xjs's Avatar
Yes they do but you may have to run an aftermarket set of valve covers. Some of the narrow body rockers fit with minor trimming of the stock cover.
Old Apr 3, 2012 | 11:31 AM
Aight cool, I have tall aluminum valve covers, relocated my alternator just to fit them.
Old Apr 4, 2012 | 08:21 AM
Bersaglieri's Avatar
You should be able to fit most rockers under that, which ones are you looking at running?
-Dustin-
Old Apr 4, 2012 | 12:34 PM
I have 7/16's studs. Looking for 1.6's, seems the prices are better on sbc specific rockers.
Old Apr 4, 2012 | 07:07 PM
omega552003's Avatar
LT4 Hotcam Kit(P/N 12480002) rockers are made to fit in the LT1/4 heads and are delf adjusting 1.6 roller rockers (P/N 12370839).
EDIT: Notice you're using 7/16th studs, my bad.
Old Apr 20, 2012 | 01:38 AM
rat's nest Z-28's Avatar
[QUOTE=greenformula94;6891242]Do sbc roller rockers fit on lt1's?
I think you need self aligning rockers for LT1? Unless you have pushrod guide plates, then maybe you don't...
Old Apr 20, 2012 | 12:18 PM
Orr89rocz's Avatar
yeah the old roller cam 87-99 sbc's have narrow body self aligning rockers. They will work on LT1. If you went guideplates, you probably can run any sbc rocker you want. Just need to make sure you have good geometry with the guideplates and pushrods.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
squinn
Aug 4, 2002 01:06 PM
