SBC roller rockers
Old Jan 15, 2008 | 10:39 PM
JAG05's Avatar
SBC roller rockers
I figured this had been talked about before but i did a search i couldnt find the answer.
Will SBC roller rockers work on an LT1? Ive been looking and some say the clear center bolt value cover others dont say that.
SBC RR appear to be much cheaper so if they will work i wanna get those.
Old Jan 16, 2008 | 10:34 AM
rich152's Avatar
The vortec style will but as for like a 70's style I am not sure.
Old Jan 16, 2008 | 11:02 AM
1SlowFormula's Avatar
as long as you get them for the correct stud's you are running you should be good to go. Mine are standard SBC RR's like so many other guys...
stick with the narrow rockers and just go out and check the part numbers and you will see they are the same for LT and non LT based SBC's...
Old Jan 16, 2008 | 03:44 PM
JAG05's Avatar
http://cgi.ebay.com/ebaymotors/1-6-S...spagenameZWDVW
Will these work? Are they SA?
Old Jan 16, 2008 | 03:51 PM
it looks like procomp changed their color to purple if those really are procomp PC2303's that is what I have been running for a while, but mine are blue...
Old Jan 16, 2008 | 09:19 PM
JAG05's Avatar
What guideplates are you using? Ive found alot of mixed opinions on those..
Old Jan 17, 2008 | 06:55 AM
Actually thiese are slightly different then mine I just re-read the ebay ad and these are non-SA rockers my procomps are...
Old Jan 17, 2008 | 01:58 PM
JAG05's Avatar
Are SA bad? Ive heard alot of ppl dont like them..
Old Jan 17, 2008 | 02:35 PM
The question is why don't they like them? SA are not bad the stock rockers are technically SA rockers, the issue is that when people upgrade parts they normally do not try and skimp out, I did it because I was only going to use them for a short while anyway and I could not see spending money on all the other stuff at the time, but when I do heads and cam the I am not keeping the SA rockers...
Old Jan 17, 2008 | 09:53 PM
JAG05's Avatar
Do i need to change the rocker stud to put guideplates under it?
Old Jan 17, 2008 | 10:10 PM
JAG05's Avatar
Ok will this work
These roller rockers:
And these pushrods:
http://store.summitracing.com/partde...tfs-30400623-8
And can I use teh stock studs with the guideplates and RRs?
Old Jan 18, 2008 | 08:58 AM
if you are spending the money on studs, pushrods, and guideplates, DO NOT skimp on the rockers... As I stated about I got the cheep rockers to hold me over until I "did it right" and got all the good studs, pushrods guideplates, and etc with the good rockers...
Old Jan 18, 2008 | 02:06 PM
JAG05's Avatar
How long would a decent set of SA last? Cuase im planning on doing a major rebuild when i get out of school in about a year.
Old Jan 18, 2008 | 02:43 PM
I've had my SA rockers for over a year with a lot of high RPM races on them, so if setup right they should last fine, but is definitly is not the ideal setup...
Old Jan 18, 2008 | 06:14 PM
JAG05's Avatar
Ok how about these for about a year or 2 until I do the rebuild?
http://cgi.ebay.com/ebaymotors/ALUMI...spagenameZWDVW
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
