Same size pushrods but different marks ?? (pictures)
Re: Same size pushrods but different marks ?? (pictures)
Originally Posted by JustNO
Describe healty, so I can tell you it is or it is not
As I said the engine is built by Thunder, they are pro, I don't think they did a mistake, but it is possible too, thats because it called "mistake".
Everything looks normal. Rockers are sitting straight. Is there any possibility to be a mistake with valve angle? I mean for the third picture, that would be because of valve angle fault?
sorry for my bad spelling
A healthy valvetrain is one that isn't doing what yours is doing.
Basically I would get Thunder involved in this ASAP.
Originally Posted by BUBBA
Well, of course, I don't know, but how do you know that your push rod length was correct to begin with----was the required length measured correctly? Obviously you are not using stock length, so there must be a reason why you are not using stock.
Originally Posted by SS RRR
I woudln't know about your valve angle. I have no idea what's exactly done to your heads. All this I'm typing is mere speculation.
Heads came from AFR with everything. There shouldn't be any mistake about valve angle.
Is the discrepancy with both the I and EX valves---don't know why, but maybe you need different sized rods for the INt and the exhaust. If the marks are off on both intake and exhaust, I'd just make sure that they chose the right sized rods. It doesn't make any sense to me that you would be getting different marks---substantially off center if you had the correct length rods with all other factors being equal----adjustments etc. JMHO
Is this normal? Look at the marks of rocker arms.
its centered.
This is different cylinder and its downside of center
And also I saw this, it is not centered??
its centered.
My name is Shane, I work here at Thunder Racing with Madman. What you are seeing in these pictures is totally normal for a large port small block chevy head with stud mount rockers. Due to the large size of the intake port, the pushrod has to be canted out at a rather extreme angle to clear the port wall. This causes the rocker arm to be angled in relationship to the valve. If you notice, all of the the marks are perfectly centered to outboard of the valve tip. The valvetrain geometry is as good as it gets for this type of setup. Normally with a large head like this, I would put a set of offset shaft mount rocker arms but since this motor was completely spec'd by the customer, i installed what was provided. What you have is totally acceptable. As the engine runs, the wear marks as in picture 3 will even out over the valve tip. If you have any more questions you can email me directly at shane@thunderracing.com.
Thanks,
Shane
Also, when i determine pushrod length, i use a solid lifter and a dial indicator to determine optimum length. The pattern you are seeing will get you as close to full advertised lift as possible.
I presume the upper part of the picture is toward the intake.
Ya got any better pictures?
It appears the PR are too short in the 1st picture on the left.Can't see it very well.
This is pretty common in some heads as the PR studs are not exactly in line with the guides. If the guide plates have the RR's in the center of the stem that's all that can be done.
Why the markings on the valve tips?
I just wanted to know if something wrong about 3rd picture. Because I can't do anything about it if something wrong, and 12 or 13 rockers are like that. Should I use lash cap? But then I must get different size pushrods.
BTW marks are just marks, smooth.
Deniz,
Thanks,
Shane
Thanks,
Shane
Could I use Shaft mount rockers with a daily/street hydrolic roller setup? I guess no
Thanks for the explanation, I hope as you say those all are normal.
The mark on the rockers is they are not contacting the valve stem perfectly square. Thats what I said in an earlier post.
Yes ya can if ya want to pay the 1500 dollars to get them.
We adjust the pushrods lenght to get marks centered, it is important that the rocker tips' pressure has to be centered isn't it?. In the 3rd picture, because the pressure is on the right side of the valve stem, it should be a problem. I mean I also have a problem with right/left side pressure.
Anyway I even don't know what will happen if the pressure isn't centered.
Does it worth ? I mean for a hydrolic setup. (for a 240/246 ~580lift cam)
Yes I know, just asking if it is a big problem or not.
Like I said the right/left thing happens all the time. It doesn't seem to bother things,but no it's not right. It would cost a set of offset lifters and shaft rockers,soo IMO it ain't worth it.(2000+dollars) Don't even know if they make offset lifters for hyd roller if not ya are talking mech roller which is more money.
Do you ask why there are markings on the valves stems? I think its normal? isn't it???
Are they impressions? Can you feel any kind of divot?
