same car, same issues, but an idea
Old Jan 31, 2008 | 12:05 AM
  #16
nes's Avatar
nes
And i read somewhere that the drive wouldnt effect the oil pressure, it simply rotates the pump shaft, the pump is either turning or its not. so any truth in this?
Old Jan 31, 2008 | 12:43 AM
  #17
ss.slp.ls1's Avatar
First pass should be 71 in. lb. Final pass should be to 35 ft. lb.
Old Jan 31, 2008 | 01:20 AM
  #18
nes's Avatar
nes
thnx, just what i needed to know... do i need to rtv the gaskets back down?? sorry for all the damn questions, i was a ford guy for so long, and never had to rtv any gaskets...
Old Jan 31, 2008 | 01:49 AM
  #19
ss.slp.ls1's Avatar
Back down...you are using new head gaskets right? You have to use rtv where the intake manifold meets the block, there's no gasket there, and continue the bead up about an inch onto the heads. This is a common leaking spot. Be carefull not to damage the oil sensor when putting the manifold back on, and as long as you remembered the vacuum configuration correctly, you should be good.
Old Jan 31, 2008 | 01:51 AM
  #20
Fatdog2's Avatar
Could be the oil pump pick-up fell off on the pan.Might ask the previous owner if he did some bottom end work.Hope this helps.
Old Jan 31, 2008 | 01:58 AM
  #21
ss.slp.ls1's Avatar
This had everything I needed when I had to replace my heads, should answer any questions about the intake manifold:
http://www.afrashteh.com/guide/install.htm
Old Jan 31, 2008 | 05:29 AM
  #22
Guest47904's Avatar
Guest
Originally Posted by nes
so car in my sig(ive made threads before), the cars gauge reads 0 oil pressure, and if the car is running the valvtrain is loud and obnoxious.
the previous owner(2 days before he sold it to me) switched the car over to royal purple 5w30(synthetics of course ) and before the car had no issues as far as oil is concerned.
Do you really believe he didn't have a problem with oil pressure just 2 days before you bought it. I got some property I think you would be interested in. Give us a break.
Second. If you have noise due to lack of lubrication. Forget about ***** footing around. It's already shot. End of story.
Old Jan 31, 2008 | 09:27 AM
  #23
nes's Avatar
nes
as stated before the pressure was fine when i bought it, the car had NOT ONE oil pressure issue until he switched the oil to synthetics, the gauge read 20psi at idle and 40psi at 5800. its a stock bottom end with 85k on it. i havnt tore it down, n im not gunna declare it shot without verification. and its funny how you are the only one saying its shot hmm...
Old Jan 31, 2008 | 10:28 AM
  #24
Colin91Z's Avatar
Nes, you could have just called and asked me to come by and help pull that intake and stuff You know it wouldn't be my first LT1 rodeo
Old Jan 31, 2008 | 12:43 PM
  #25
nes's Avatar
nes
havnt pulled it yet, but your more then welcome to come help
Old Jan 31, 2008 | 02:34 PM
  #26
Colin91Z's Avatar
When are you planning to do this?
Old Jan 31, 2008 | 04:31 PM
  #27
nes's Avatar
nes
possibly tomarrow afternoon sometime...
Old Jan 31, 2008 | 05:25 PM
  #28
Colin91Z's Avatar
I wouldn't be able to make it in the afternoon cause I'll be at work, but maybe I could swing by on Sat afternoon after you have it all apart to take a look at it and help you put it back together...
Old Jan 31, 2008 | 06:20 PM
  #29
Z95m6's Avatar
Well if it happened over the weekend I'd come stand around and laugh while every one busts their knuckles.
Old Jan 31, 2008 | 09:17 PM
  #30
pizzi-man's Avatar
There were threads about the oil pump drive problem. The piece that holds the drive in place is made out of plastic of some sorts and has been breaking under certain circumstances. If the pump shaft retainer was to break and the pumpshaft were to be pushed up it just might disengage from the pump. That would cause no oil pressure. Cam turns pump shaft turns oil pump.
