Is this safe?
Old Apr 3, 2005 | 10:49 PM
Digital Designs's Avatar
Is this safe?
Would it be safe to run 1.6rr's on a stock IMPALA lt1 with a set of valve springs from a 94 camaro?
Old Apr 3, 2005 | 11:08 PM
madwolf's Avatar
Re: Is this safe?
Some people will say you can, but I definetely wouldn't. If you are going to replace the valvesprings, get the right ones. Find a set of used hotcam springs at least.
Old Apr 3, 2005 | 11:22 PM
Re: Is this safe?
Well i know the impala cam with 1.6 rockers would make the lift 0.446 intake and 0.459 exhaust. The stock camaro cam that was used with the springs with 1.5 rockers is 0.450 intake and 0.460 exhaust........ i was wondering if it would cause damage or not work even though the lift is virtually the same that it saw from the factory. Reason im asking is i have a impala engine in my 94 camaro and swapped the iron heads or the alums from the old engine but left the stock cam.
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 24, 2015 11:04 PM
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
Jan 23, 2015 01:13 PM
