RWHP Should be higher? What limitations
Old Jul 12, 2007 | 01:43 PM
  #31
stereomandan's Avatar
Did the tuner mess with the timing, or do you know if you were getting any knock retard?
Everything else looks great and it's the only thing I can think of. Maybe your timing is off (too low causing loss of power), or too high, causing knock retard and loss of performance.
Dan
Old Jul 12, 2007 | 01:51 PM
  #32
blakeforslund's Avatar
more info and dyno runs
no knock retard and full-timing. Brought timing down a degree and only lost a half a hp.
And what is SAE smoothing?
Old Jul 12, 2007 | 02:34 PM
  #33
ALso what is SAE corrections?
Old Jul 12, 2007 | 02:51 PM
  #34
tireburnin's Avatar
SAE is a correction factor that is set at 70degrees, zero altitude and moderate humidity. It basicly takes out factors like high elevation or low air temp. It is the standard with which people compare dyno numbers because it eliminates the variance in location etc.
Old Jul 12, 2007 | 03:01 PM
  #35
reamo04's Avatar
what is the giant torque spike from? what stage of heads are those? The intake side is a little low, that could also be hurting you a little too.
Old Jul 12, 2007 | 03:05 PM
  #36
Sweetred95ta's Avatar
Are you positive of no knock retard? What is full timing? I'm still not seeing 420 rwhp @ 6800.
Old Jul 12, 2007 | 05:01 PM
  #37
marshall93z's Avatar
Peaked a little low.
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Sep 11, 2015 09:44 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
