Is this to Rusted???
Old Nov 4, 2003 | 12:30 PM
drewstealth's Avatar
I think i need a new driveshaft. This is a good price for one. Do you think its okay or is it to rusted?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Nov 4, 2003 | 01:07 PM
Mtrhds94Z's Avatar
That's no more rusty than the average STEEL driveshaft.
My question is, if it's 'off an LS1', why isn't it aluminum?
And you should be able to get used steel ones real cheap, I'd think.
Old Nov 4, 2003 | 01:20 PM
madwolf's Avatar
Looks like a steel driveshaft to me. Aluminum doesn't oxydize like that.
The guy obviously doesn't know what he's talking about.
Old Nov 4, 2003 | 01:21 PM
WOT's Avatar
WOT
LS1's with non z-rated tires got steel driveshafts and a low speedo limiter.
Old Nov 4, 2003 | 01:32 PM
chesee48's Avatar
yep yep, that is true, i was gonna just say that.
Old Nov 4, 2003 | 01:41 PM
Dave Holland's Avatar
Wouldn't be too concerned about the rust. The yoke looks pretty clean which is good. Too much $ though. I found one locally for $20 when I was looking for one to slap in my v6 beater to get rid of the junk 2 piece they come with.
-Dave
Old Nov 4, 2003 | 01:47 PM
Oh okay i was wondering why a aluminum one would have rust on it. I need an aluminum one because i get really bad vibrations at 90mph so i'm gonna try to see if a ls1 shaft will cure it. If i can't find one cheap then i will just get a new 1le.
Old Nov 4, 2003 | 01:59 PM
grendal's Avatar
I think an LS1 steel and an LT1 steel shaft are exactly the same. I don't know that you'll get any benefit out of it. Your DS isn't vibrating because it's steel, it's vibrating because it's out of balance. There's no guarantee that this one would be any more balanced....
The advantage would be to upgrade to an aluminum driveshaft, which this isn't.......
Rather than spend $40 (total) for this, you might ought to look into an aluminum one at a local junkyard, or maybe see if any shops do drive shaft balancing.
-Michael
Old Nov 4, 2003 | 05:02 PM
BUBBA's Avatar
If you can't afford a new one, find a good balancer.JMHO
Old Nov 4, 2003 | 05:18 PM
94formulabz's Avatar
Before that, try loosening it and rotating the driveshaft 180 degrees. It's worked for a few people.
93 RedBird
Nov 15, 2015 08:24 AM
BMX Dad
Aug 15, 2015 01:15 PM
Anon
Jul 23, 2015 12:18 PM
Camarokid95
Jun 12, 2015 11:25 PM
