Rust on rocker arms?
Old Oct 21, 2003 | 08:09 PM
97 RedSS's Avatar
For some reason when I pulled my valve covers I found a rust substance on my Comp Pro Magnums? What could be causing this and why?
Cody
Old Oct 21, 2003 | 08:54 PM
jasons93z's Avatar
coolant in the system?
Old Oct 21, 2003 | 09:32 PM
97 RedSS's Avatar
Havent lost any coolant in the last yr since the motor has run..
Not sure what could be causing this
Cody
Old Oct 21, 2003 | 09:36 PM
jasons93z's Avatar
the only thing that i could think of was water on the rockers.
Old Oct 22, 2003 | 10:44 AM
97 RedSS's Avatar
Anyone else?
I talked to Comp Cams about it and I am waiting on a call back from there warranty department..
Cody
Old Oct 22, 2003 | 10:49 AM
jasons93z's Avatar
Originally posted by 97 RedSS
Anyone else?
Cody
Have you let the car sit around for a long time, undriven?
Old Oct 22, 2003 | 10:55 AM
drewstealth's Avatar
I would think that you got some water in there somehow. But then the car would still have to sit for a little while to cause rust.
S.J.S.'s Avatar
Are you sure its rust. I see you said that it was a rust like substance. I've seen old parts that get burnt from the oil with a bronze tinge to them. Dunno if that sounds funny but just curious. But unless you got water in your oil and your car hasn't been sitting I dunno what it could be.
Old Oct 22, 2003 | 11:54 AM
97 RedSS's Avatar
It does sound like its more of a oil substance that was burned..I remember when I installed my Canton Oil pan I saw the same thing on a few of my maincaps.
I only drive the car 25-50 miles a week if that...
Why would the oil do this?
Cody
Old Oct 22, 2003 | 12:31 PM
S.J.S.'s Avatar
Whoa.....I actually was correct on that shot in the dark. It's just oil slightly burnt onto the metal from the extreme heat. Not a big deal. Get some solvent if you want. It cleans them off.
Out of the motor of course.
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
