running without tune???
Old May 17, 2010 | 07:49 AM
jklopez09's Avatar
how bad should my car run with out a tune? i just did cam swap with full rollers. it wants to cut off when you give it gas while driving but idles and revs normal. all mods are in sig. Also how much horsepower yall think i will be pushing after tune and lt headers? Can i order a tune before headers or is it better to wait until after?
Old May 17, 2010 | 05:10 PM
joeSS97's Avatar
Check your vacuum lines. The one on the fuel press. regulator too. It should run ok,but you really need a tune. As far as HP,after a good tune 330 @ the tires,maybe.
Old May 17, 2010 | 10:40 PM
jklopez09's Avatar
where is a good place to get a chip burned?
Old May 18, 2010 | 12:33 PM
jklopez09's Avatar
what else would cause it to stall when i give it gas while its in gear? rocker adjustment?
Old May 18, 2010 | 12:37 PM
raroz28's Avatar
If you don't know how to set valve lash don't drive it until you find somebody who can help you or you'll bend a valve.
If your valve lash is far off your car won't run good, or at all in some cases.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
