Running w/ out 02's..how bad?
Old May 29, 2008 | 02:23 PM
Jazsun's Avatar
Will I foul all my new plugs if I drive .5 miles w/ no 02's plugged in. I know it will run rich but will that cause them to foul?
Old May 29, 2008 | 03:02 PM
Z28blake's Avatar
Don't they run in open loop when first started . So its not looking at the o2s in open loop.
Old May 29, 2008 | 09:50 PM
sbs's Avatar
sbs
As long as the open loop part of the tune is not ridiculously off it should be fine.
And - you don't know it will run rich. Could run lean; could run perfect.
Most likely it will run rich under some conditions and lean under others and perfect under yet others. Just like the cars of yore...
Old May 29, 2008 | 11:38 PM
jammer94's Avatar
as bad as the $5 a gallon you have to waste but it can be done and for a while but it will kill your tank a little faster then before.
grabbem88
Feb 13, 2015 03:09 PM
Amshnock
14
Jan 18, 2015 11:47 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Z284ever
43
Jun 27, 2002 10:36 AM
