running lean and TPS
Old Oct 2, 2003 | 05:53 PM
Seal's Avatar
I got an SES light today, and it comes out to 'Throttle Position (TP) Sensor Circuit Low Voltage' and also it shows i'm running lean (cant remember which code# this was) (most likely the o2s are shot since the prev guy didnt change them, and i got 90K miles)
how much are o2 sensors? (cheapest one i can get :P) i believe i need 4? (maybe i can get sims for the back since they would be cheaper) but i need sensors for the front 2 i believe...
also how do i fix the TPS voltage problem?
thx!
Old Oct 2, 2003 | 06:25 PM
InjectedSS's Avatar
Check the screws on your TPS switch that's on the throttle body. It prolly came loose. If you have access to a scanner you can look at your TPS voltage, it sohuld be somewhere from 0.50 - 0.62
Old Oct 2, 2003 | 09:45 PM
Seal's Avatar
will do, any other ideas that can be possible?
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Feb 13, 2015 03:09 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
