Running hotter after H/C install
Old Apr 11, 2007 | 11:25 PM
camzaro28's Avatar
Before the H/C install my engine temp would run in the mid 160 range, now it is running a lil hotter. In the mid 170. Could that be due to having more water then coolant in the system? Or is this normal?
Old Apr 11, 2007 | 11:54 PM
blown383's Avatar
Did you completely flush and burp the cooling system? Checked the thermostat and radiator cap? It might even be that you're low on coolant.
-B
Old Apr 12, 2007 | 06:19 AM
red 95 z28 lt1's Avatar
i think that fine my car runs at 180 deg and i have a 160 t stat
Old Apr 12, 2007 | 06:25 AM
BlackScreaminMachine's Avatar
Properly bleed the system, unless timing has been changed or your running lean, combustion chamber temps shouldnt alter coolant temps.
Also to be noted, stock guages are iffy, use a program that reads the pcm's info on coolant temp.
Old Apr 12, 2007 | 10:39 AM
camzaro28's Avatar
I have the 160 stat as well, but why after the H/C install would the temp rise 10 deg?
I bleed the sytem, shouldnt be any air in the lines. But will double check that.
alphaauto
Jan 22, 2015 08:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
