Running Hot at idle
Old Sep 23, 2003 | 07:27 AM
bandit_1981's Avatar
Exclamation Running Hot at idle
My 97 ta runs about 180 when driving but when idling it runs about 210 or so. I find this to be to hot for it and turn the heater on to force the fans on then the temp goes down to 180 again. I think my thermostat might be bad and not kicking on the fans. Please advise.
Old Sep 23, 2003 | 07:38 AM
Spinner's Avatar
Your thermostat has nothing to do with your fans.
Old Sep 23, 2003 | 07:49 AM
OK cool but do you know why it would run hot only at idle.
Old Sep 23, 2003 | 07:55 AM
Spinner's Avatar
I think (not completely sure) that it's because the water pump is crank driven, and at speed, pumps/circulates water (coolant) much faster then at idle, on top of the extra airflow you get when your car is moving. It's normal for it to be hotter at idle, at least my car is. (Fresh pump, fresh 160 thermo)
Old Sep 23, 2003 | 09:54 AM
IXLR894Z28's Avatar
Your fans will not kick in untill around 215 for low and 225 for high, Those numbers may be a little off, but the temps you speak of are normal for our cars when they are stock. Drop a 160 degree thermo in it if you want to run cooler.
Old Sep 23, 2003 | 09:56 AM
Oh ok cool because it would sometimes creep towards 220 mark and scare the hell out of me but if they run that hot then it is cool with me. I plan on putting a thermostat in it to.
Old Sep 23, 2003 | 11:15 AM
97Z-M6's Avatar
i started having that problem. and i just advanced the timing to 28 degrees at the rpm and the MAP that the car idled at. and my car will now never get above 185 with a/c on and idleing in the heat of texas.
Old Sep 23, 2003 | 12:17 PM
BMC95TA's Avatar
Also you can install a fan switch and turn the fans on whenever you want to either low or high.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
