Running Car with blown head gasket?
Old Feb 26, 2006 | 07:28 PM
Z28LT1_Just_Nasty's Avatar
What kind of damage can be caused by running my camaro with a blown head gasket only for maybe a minute or two at a time to move it around? I've had to move it twice but only for about 20-30 seconds at a time.
Old Feb 26, 2006 | 08:12 PM
tgw323's Avatar
Re: Running Car with blown head gasket?
At this point I don't think it'll make much difference.
Old Feb 26, 2006 | 08:13 PM
tgw323's Avatar
Might want to drain the water to make sure it doesn't hydraulic.
Old Feb 26, 2006 | 08:21 PM
turbo_Z's Avatar
I think it depends where and how bad its leaking. If you are getting coolant in the oil then you may ruin the bearings but if its just a small leak into a cylinder then you could drive it a long time without any real problem... unless the leak gets worse or burn off all the coolant that is. So its all about the degree of leakage and where its leaking that will determine any potential harm to the motor.
Old Feb 26, 2006 | 08:22 PM
BlackScreaminMachine's Avatar
I had a bent valve, no head gasket, loss of compression and I could move it but since it was the intake the cyl had been washed down with gas. Just watch for the coolant.
Old Feb 26, 2006 | 08:24 PM
Evil Eric's Avatar
Ive heard that dex-cool in your oil will eat up your bearings.
Old Feb 26, 2006 | 08:46 PM
GreenDemon's Avatar
It would be a good idea to drain the coolant from your block. At the least take off the radiator cap so the system doesn't pressurize.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
