running on 7 cylinders... injector help
Old Jan 4, 2013 | 02:34 PM
  #16
Guest47904's Avatar
Guest
But then there are those that get pissed when we ask questions like ......
Originally Posted by Cbystrack
just in case anyone wanted to know that a stopp'd up air filter will cause tons of issues.....
I guess sometimes you got to look at even the things you would doubt being wrong......
Actually we as "advisers" have to quit thinking that the simple items have been looked at and ask that question to begin with.
But then when we ask others if they checked the air filter, they usually get irate. I once had an argument with someone on this board that swore a wet air filter would not cause a problem. Which BTW is easily done since the air filter is so low in the car and many cut holes in the box thinking they're getting more horse power or some such non sense.
Old Jan 4, 2013 | 02:38 PM
  #17
bw_hunter's Avatar
Re: But then there are those that get pissed when we ask questions like ......
Chuckle. If you go back and read the verty first post the OP talks about a single cylinder not firing or looking lean. It's a big leap from a dirty airfilter to a single lean cylinder...so much of a leap that I doubt the air filter change actually fixed it. Better check it again....
Old Jan 7, 2013 | 04:22 PM
  #18
Cbystrack's Avatar
Re: running on 7 cylinders... injector help
the issue is still here. im running rich.... i just have no responce and my friends stock 99 gt mustang walks ALL over me.... sorry for not looking in obvious spots to start with.
any advice at all for me.... i changed all 8 injectors to known good ones..... pig rich still
thought a stop'd up air filter fixed it but im still on square one
AdsoYo
May 2, 2018 03:21 AM
Alex Barnes
Jan 24, 2015 10:21 PM
birdblack
Dec 30, 2014 06:59 PM
nophix
Nov 30, 2014 10:26 PM
