RTV on header gaskets?
Old Mar 22, 2004 | 12:20 PM
Cmr0z28's Avatar
Do you guys use RTV silicone on your header gaskets?
Old Mar 22, 2004 | 01:07 PM
Hyperspeed97z28's Avatar
I used copper RTV around the ports on mine.. Been over a year leak free ...
Old Mar 22, 2004 | 01:32 PM
stereomandan's Avatar
I've seen header install guides that recommend it.
Does the header gasket area get too hot for the Permatex Ultra Copper RTV? I'm not sure.
I think I have a header leak or a collector leak and want to put some Ultra copper on there, but don't want to go past it's usable temp range.
Thanks,
Dan
Old Mar 22, 2004 | 01:53 PM
Cmr0z28's Avatar
Everyone tells me to use copper.......guess I'll pick some up from wal-mart.
Old Mar 22, 2004 | 01:54 PM
Cmr0z28's Avatar
do you use a thin or thick bead around the ports?
Old Mar 22, 2004 | 02:00 PM
Scream And Fly's Avatar
When I helped a friend install his BBK shorties in his 94Z, we used Ultra Copper. We ended up running a thick and clean bead around the gasket on both sides, and set the gaskets up so they could partially dry. While it was somewhat dry but tacky, we installed headers with the gaskets. It's kinda' tricky to do it that way, but I think it's best in the long run.
Worked perfectly, and that's how I'll do it again.
Greg
Old Mar 22, 2004 | 02:06 PM
Cmr0z28's Avatar
Thank you
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
Queens94z28
Dec 20, 2014 09:11 PM
