RR's
Old Jul 9, 2004 | 02:05 PM
got8?'s Avatar
RR's
How hard are the is it to put in rr's i hear they fit under the stock valve covers
Old Jul 9, 2004 | 02:33 PM
BUBBA's Avatar
Depends. The more specific you are about the type and brand of RRs, the more specific the responses.
Some brands require a little bending cover metal to accommodate. Non-self aligning will require hardened push rods and quide plates. Self-aligning, no.
Larger, e.g. 1.6 rockers should have stonger springs which requires spring installation.
All depends...
Old Jul 9, 2004 | 02:38 PM
Somnambulist's Avatar
you can run 1.6 SA rockers on stock springs with no problems.
Old Jul 9, 2004 | 03:30 PM
Red96Lt1's Avatar
Do you really need hardened push rods?
Old Jul 9, 2004 | 03:43 PM
Amped96's Avatar
Yes, you defiantely need hardened pushrods when you are running NSA rockers with guideplates.
Old Jul 9, 2004 | 05:22 PM
RE AND CHERYL's Avatar
Have you done this? How much lift can the stock springs take? I beleive the stock cam life is like .450.
The 94 LT1 already had hardened pushrods. But all other years will require hardened pushrods if you run NSA rockers.
Old Jul 9, 2004 | 05:32 PM
ive been running 1.6 SA rockers on my car for a little over 5k miles...
and all '94's didnt have hardened pushrods...yea some did as well as some in '95...
