rpm module
Old May 4, 2006 | 02:13 PM
bazzi's Avatar
rpm module
ok i just installed a auto meter shift light and i need a rpm module to make it work. it says to connect the green wire to the tach terminal. where is the tach terminal? do i have to connect there? i have a 95 z28. thanks for the help
Old May 4, 2006 | 04:06 PM
jsetzer's Avatar
Re: rpm module
2 common places. You can use the coil, or I used the wire coming off the back of the pcm. Check shoebox's website for the pinout.
Old May 4, 2006 | 05:13 PM
seawolf06's Avatar
Re: rpm module
Is the wire off the pcm going to be more accurate? I know the stock tach is always off, so I want to make sure my light is right on.
AtlasXVIII
Aug 24, 2015 11:41 PM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
karpetcm
Aug 14, 2015 03:02 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
