Rough Idle/Skipping
Old Jun 9, 2015 | 07:25 PM
jmadoll's Avatar
Rough Idle/Skipping
A couple weeks ago I had a Code 16. Changed Opti, Spark Plugs and wires. The code went away. Now the problem I'm having is when sitting at idle the engine is skipping a lot and the voltage drops especially when you are running the A/C. When you are driving the car runs fine. Any suggestions on what to check? Thanks!!
Old Jun 10, 2015 | 10:02 AM
Fatdog2's Avatar
Re: Rough Idle/Skipping
Idle control valve?
Old Jun 10, 2015 | 04:41 PM
timnfxr's Avatar
The low voltage you referred to, is that measured at the battery? If so, it should be approx. 14-15 VDC (engine at idle, no A/C). If its much lower, it may be the alternator. Are you using under-drive pulleys? That would account for the lower than normal charging voltage.
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
