Rough idle and loud poping noise. Help
Old Sep 4, 2003 | 07:02 PM
gabez28's Avatar
Unhappy Rough idle and loud poping noise. Help
well it started this morning. I heard a noise that sounded like maybe an exhaust leak. So as I go home the noise is still there but now im getting a very rough stumble while crusing @ aorund 1500 rpm's as I release the gas and brake a loud pop comes from the cutout like backfire but very loud. this happens all the way home.i checked all the plugs and wires thinking something is loose and everythings fine. As I listen I hear a ticking noise coming from the drivers side valve cover area and I give it a little gas and another loud pop came from the cutout as it backfired. I need some help guys. Im kinda scared to drive it cause I dont want to f it up any more.
Old Sep 4, 2003 | 07:54 PM
MK 94 1LE's Avatar
I broke a valve spring and it had very similar problems. Pull the cover off side with the tick and check for a loose rocker arm.
Mike
Old Sep 4, 2003 | 11:15 PM
gabez28's Avatar
What should I look for? Would it be safe to drive for a few days???
Old Sep 5, 2003 | 06:47 AM
gabez28's Avatar
Old Sep 5, 2003 | 09:07 AM
'94 Bad A Z28's Avatar
Might wanna check around the plugs while the car is running... You might have cross threaded a plug, leaving a small gap between the plug and the head. (There's you exhaust leak sound.) Don't ask how I know this.
eagle54348
Jun 15, 2015 05:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
TrouserSnake
Jul 29, 2002 11:24 PM
