Rough Idle, and doesnt want to hold RPMS
Old Mar 25, 2004 | 09:34 PM
2Fast94TA's Avatar
my car idles like it has a big choppy cam in it but at idle it stalls out. i can pump the throttle to keep it running, but if i try to hold it at 2k rpms it doesnt hold there and just jumps down and stalls. my fuel pressure jumps to 43 psi then drops to 40, with the engine running it goes to 37.
Old Mar 25, 2004 | 09:45 PM
Robs97Z28's Avatar
fuel [resure is a little low, but how mary miles on the clock? The last time you did a tune up? Replace the cap and rotor?
Old Mar 25, 2004 | 09:55 PM
2Fast94TA's Avatar
i just bought the car with 58k miles, i ran it for 2k and then it just started to do this, i have replaced nothing on the motor and not sure what has been changed, i bought it at a dealership seems like they would do a tune up before selling, are there any tests i can do to make sure its not the opti or any other sensors?
Also i have heard a rumor that you can check for codes with a paper clip by connecting the A and B terminal?
Old Mar 25, 2004 | 10:10 PM
Robs97Z28's Avatar
most of the sensor like maf, tps, map , and o2 should throw a code. you can see if your egr is working by seeing if you can open it by hand. It is on the back of the manifold. push on the diaphagm and see if it open freely and that it is suck. If you can keep the car running as you open the egr at idle the engine should die.
Old Mar 25, 2004 | 10:11 PM
Robs97Z28's Avatar
did you have a vacuum gauge?
Old Mar 25, 2004 | 10:13 PM
Wildwill2855's Avatar
Possibly , what it was for me anyway was the PCV the rubber boot tore and man it sounded like a CC306 in there lol!
Old Mar 25, 2004 | 10:24 PM
2Fast94TA's Avatar
i have been noticing a ticking sound could that mean a bad pcv?
and no i dont have a vac gauge
Robs97Z28's Avatar
I did not think of that. that happened to me while I was replace my pcv valve.
Old Mar 26, 2004 | 06:47 AM
2Fast94TA's Avatar
well im going to clean the IAC the EGR and replace plugs and wires. can anybody else think of something?
grgguy
17
Feb 23, 2015 07:57 PM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
TrouserSnake
Jul 29, 2002 11:24 PM
