Rotating Assemblies
Old Sep 18, 2005 | 12:47 AM
blahster's Avatar
Rotating Assemblies
Does it matter what rotating assembly i get for my LT1? will any SBC rotating assembly work or do i need to get one that is LT1 specific?
Old Sep 18, 2005 | 01:12 AM
rskrause's Avatar
Moderator
Re: Rotating Assemblies
The crank will need to have a 1-piece rear seal.
Rich
Old Sep 18, 2005 | 01:34 AM
blahster's Avatar
Ok so the 1pc seal is the only thing i need make sure it has? nothing else i need to worry about? i will be doing a 383 LT1 4-bolt LE3 setup...thanks!
Old Sep 18, 2005 | 02:04 AM
rskrause's Avatar
Moderator
Well, you need to decide on internal v. external balance, compression ratio, rod length, type of materials, etc. But nothing else unique to an LT1.
Unless you know exactly what you are doing, it's usually best to buy the entire rotating assy. as a unit. This often saves a few bucks, but more importantly you know everything will fit together! Unless you are assembling the motor yourself, ideally the shop doing the work should buy the parts. That way, there is no question who is responsible for what.
Rich
Old Sep 18, 2005 | 07:26 AM
LameRandomName's Avatar
Just a heads up...
Some folks will tell you that you can run other than an LTx crank in your LT1.
Technically, this is true, but in reality it creates more work that you and/or your machine shop needs to do and more stuff you need to buy.
I suppose that there could be unusual circumstances where you might not care, but in general; if anyone suggests running a non-LTx crank in your engine, just tell them no thanks.
Old Sep 18, 2005 | 12:58 PM
MachinistOne's Avatar
LT1 are just cut differently for the lighter pistons that come stock. LT4 cranks are also lighter, but have different fillets.
THERE ARE NO LTX SPECIFIC AFTERMARKET CRANKS!
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Aug 27, 2015 06:37 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
