Rotate/Remove Coolant Tubes on Water Pump?
Old May 26, 2005 | 10:35 AM
Birdie2000's Avatar
http://community.webshots.com/photo/...53759490VoGpYs
This tube interferes with my blower brackets. Can it be rotated to face downwards without any leaks? Or, can it somehow be removed and reinstalled, or a new one installed, facing another direction? Worst case scenario I'll have it cut off and a -AN fitting welded onto it, but that really is a last resort.
Old May 26, 2005 | 11:31 AM
OBE1 95Z28's Avatar
Re: Rotate/Remove Coolant Tubes on Water Pump?
The Vortech instructions tell you to rotate that waterpump port. I found that a ratchet extension fit the port nicely to allow me to rotate it out of the way; no leaks.
Old May 26, 2005 | 11:42 AM
Compstall's Avatar
The tube is only pressed in there, so I'm sure it won't be a problem. If it seeps/leaks (one of mine did) you can glob some JB Weld around the seam. Mine's been that way for 4 years now.
Old May 27, 2005 | 04:22 AM
1982z28with18s's Avatar
You can remove it and then put it back in at the correct angle using locktite sleeve retainer. I just put mine back in about 3 weeks ago and its fine and I have a buddy who has done it and it was fine for years on a few cars.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
